View multiple spanning tree instance (MSTI) port statistics to manage network performance.
- Select MSTP.
- Select the MSTI Port tab.
- Select a port, and then select Graph.
MSTI Field Descriptions
The following table describes parameters on the MSTI tab.
Name |
Description |
ForwardTransitions |
Specifies the number of times this port has transitioned to the forwarding state for this specific instance. |
ReceivedBPDUs |
Specifies the number of BPDUs received by this port for this spanning tree instance. |
TransmittedBPDUs |
Specifies the number of BPDUs transmitted on this port for this spanning tree instance. |
InvalidBPDUsRcvd |
Specifies the number of invalid BPDUs received on this port for this spanning tree instance. |
